hey, im trying to build a new pc around 600e budget range.
i just found a used I5 3570k and ASRock z68 extreme3 gen3 for 200e, and i was wondering if it was a good deal.
Also what else would you guys get to complete the build and stay in the budget range. i dont need the operating sistem and the case, so you can count those out.
thanks in advance!
https://linustechtips.com/topic/623016-help-with-a-600e-budget-pc/
what country, what use, and what case do you have.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
I'm from Serbia so the price of everything is gonna be about 20% higher. that being said i have a larger budget so i said 600e with that 20% in mind.
i'd use the pc to play games mostly.maybe be able to stream/record  some older games like league, maybe overwatch (if possible, not a  priority).
and for a case i have a Corsair Carbide spec alpha that i got as a present and a 650w raidmax ps that i got from a friend who upgraded.
that seams like a good deal
10 minutes ago, Tufjghf said:
any ideas for the rest of the build? what should i get?
http://pcpartpicker.com/list/9YD8Yr
