1. Budget & Location
You may have listed a heap of parts that all add up to your preferred budget but it is easier if you just list the total amount you'd like to spend and the currency as well as if you'd consider going above that budget for more performance. We need the location as well because $US are different to $AUD and $CAD ect.
Romania. Budget is around 7000-8000 RON (around 1900 USD). You can send me the part links from any website, I'll just search for them here in Romania
2. Aim
What is the system going to be used for? Web browsing, 3D work? Different systems need different levels of performance - a computer based for web browsing and office use won't handle heavy graphic design and video editing and a proper video editing system isn't good for gaming. If your aim is for gaming, please list what sort of gaming. In the same way that different usage types need different systems, you'll need a lot more power to run Far Cry 3 or Crysis 2 than you would Minecraft.
Gaming, some light video editing. Games mostly play are ARMA3, GTA V and IV, FarCry4, Battlefield One, mostly AAA titles.
3. Monitors
How many monitors do you plan on running? Do you plan on moving to more monitors in the future? What resolution are they at too?
I will use the 144hz monitor mentioned below and I will hook up an old 21 inch as my second display
4. Peripherals
Do you also need to purchase peripherals such as keyboards and mice as well as monitors ect. Also please tell us if you'll need an OS such as Windows.
I need an 144hz monitor, an BenQ XL2411Z or XL2430T
Also, I need windows
If possible, I want an i7 included, just to be futureproof.
If Overclocking doesn't do much difference, I won't do it
I need it to be silent
I would like an BLACK and WHITE theme if possible.
Needs to look good :P
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
If you're good at something, never do it free.
https://linustechtips.com/topic/622965-need-some-help-2000-build-suggestions/
PCPartPicker part list: http://pcpartpicker.com/list/YdvV6X
Price breakdown by merchant: http://pcpartpicker.com/list/YdvV6X/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($345.88 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($43.53 @ Amazon)
Motherboard: Gigabyte GA-Z170MX-Gaming 5 Micro ATX LGA1151 Motherboard  ($136.99 @ NCIX US)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($64.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  ($419.99 @ SuperBiiz)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($39.99 @ Newegg)
Power Supply: *Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Monitor: BenQ XL2411Z 24.0" 144Hz Monitor  ($267.00 @ Amazon)
Total: $1525.84
Generated by PCPartPicker 2016-07-08 12:16 EDT-0400
mATX build. Sth to think of. :P. Windows is easy to get cheap from reddit or some online keystore (30USD). 1500USD and leave 400 to cover tax and staff, (finger crossed for 1070 not to be 500USD in ur country!)
