Tt Challenger Pro Launch Macro
Go to solution Solved by wraptor,
Configure the key to do the following combination:
CTRL + SHIFT + ESC
This is the keyboard shortcut for Taskmanager and would not require the software to open any folders ;)
Hey there,
I have a Tt Challenger Pro Keyboard and am trying to set one of the macro keys to launch Task Manager. The Software enables me to bind it to launch, and then I set it to launch the Task manager exe (Taskmgr.exe in System32). This does open Task Manager however it also opens up the location of the exe in Windows Explorer. Even more curious is that if I have the keyboard software open then it works as it should. I've tried making a shortcut, putting it elsewhere and launching from that but it has the same result.
Hoping that someone with experience with macros is familiar with this.
Thanks in advance
https://linustechtips.com/topic/622882-tt-challenger-pro-launch-macro/
