I am considering purchasing a UPS for my computer, for a 850 watt PSU what would be a good UPS? I was looking at the CyberPower PFC Sinewave Series UPS 1500VA - 900W.
Things i want to plug are, my computer and my monitor, maybe my router too...what do you think?
https://linustechtips.com/topic/621971-ups-for-850watt/
What are your system specs we can get a better idea of your needs than just going off the PSU. As for some good brands, APC and Cyberpower are both good options.
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022679
Sorry,
My computer consists of:
6700k
H110i
GTX 1070 Gaming 8X MSI
2 SSD
1 M.2
2 HDD
5 case fans + 2 from H110i
all gaming periferals, keyboard, mouse, usb microphone
PSU: Super Flower 850w or Corsair AX1200i (if i get it RMAed)
monitor: Asus ROG Swift
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022691
http://www.bestbuy.com/site/apc-power-saving-back-ups-xs-1500-black/9307831.p?id=1218081367518&ref=199&loc=8BacdVP0GFs&acampID=1&siteID=8BacdVP0GFs-vSN4RKj8XFULo_5BjgqlhA
This is the UPS I'm using for my build. I would highly recommend it. I've had it for 5 years and only had to replace the batteries in it just recently (they cost about $50).
CPU: Delided Intel Core i7-6700K | Motherboard: Asus ROG MAXIMUS VIII HERO ALPHA | RAM: G.Skill Trident Z 16 GB (3600/15-15-15-35) |GPU: Asus GeForce GTX 1070 8GB STRIX | Case: Fractal Design Meshify C Dark TG | Primary SSD: Samsung 950 Pro Series 512GB (OS/Games/Programs) / Seagate 5 TB External Hard Drive (Media) | PSU: SeaSonic Prime 650W | Cooling: be quiet! Dark Rock 4 + 4x Corsair ML140 Pro LED Red + 1x Corsair ML120 Pro LED Red
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022705
This costs 120 Euro more in Europe compared to Cyberpower sadly
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022708
4 minutes ago, reystar said:
-SNIP-
Your system wouldn't use that much power even at max load maybe just about 400W so your could go for a smaller unit unless your planning on getting a second GPU or adding lots of things to be powered at the same time. For a smaller unit something like theses would work great:
https://www.cyberpowersystems.com/products/ups/desktop/cp1000pfclcdtaa
http://www.apc.com/shop/us/en/products/Power-Saving-Back-UPS-NS-1080VA/P-BN1080G
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022713
I might go for 1070 SLI, i am not sure yet,. Wouldn;t it be safer with the 1500VA? The 1000VA model will be good enough to handle 2 cards?
Also, my 6700k is oced at 4,6GHz atm and i might oc my 1070 too
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022773
For a singel card the smaller unit would be enough even if you did some overclocking, but if you are planning on a second card or lots of high power draw peripherals like sound systems then the larger unit wouldn't be a bad idea since it gives you the ability to expand later on.
https://linustechtips.com/topic/621971-ups-for-850watt/#findComment-8022788
