I came across a bit of an issue when I tried to specify an instance, and it thinks i'm trying to do an "escape sequence".
Here is the line of code:
        The error lies here |
PerformanceCounter perftemperatureCount = new PerformanceCounter("Thermal Zone Information", "\_TZ.TZ00");
Motivation is where, and what you make of it.
“It is relatively unusual that a physical scientist is truly an atheist. Why is this true? Some point to the anthropic constraints, the remarkable fine tuning of the universe. For example, Freeman Dyson, a Princeton faculty member, has said, ‘Nature has been kinder to us that we had any right to expect.'”  Albert Einstein
https://linustechtips.com/topic/621656-need-help-with-c/
24 minutes ago, Mr_KoKa said:
"\_TZ.TZ00"
If you aren't about to escape _ character then try  "\\_TZ.TZ00" \ is escape character that tries to escape following character, \\ will be just single backslash in result.
Thanks!
https://linustechtips.com/topic/621656-need-help-with-c/#findComment-8018400
You can also use a verbatim string literal by placing the @ symbol in from of the quoted text.
@"\_etc"
This removes the need to escape characters, except the double quote character which is added like so
@"Example: ""Hi"" they said."
It also allows you to write multiline strings that keep line breaks and spacing intact.
@"Hello
    World"
With C# 6, they introduced interpolated strings which you can also combine with verbatim strings.
Stackoverflow: How do you use verbatim strings with interpolation?
https://linustechtips.com/topic/621656-need-help-with-c/#findComment-8019731
@madknight3 Explained it well.
An even more fun (and less known) trick using the "@" sign is that it allows you to use C# keywords as variable names. I never recommend this, but it does work. You can write things like this:
void Main()
	var @null = "HEY";
	var @if = "WHAT R U DOIN";
	var @object = "PLZ STAHP";
	Console.WriteLine($"{@null} {@if} {@object});
Once again, don't do this without a very, very good reason. It's just a neat example of how consistent the "@" signifies the idea of doing something verbatim.
https://linustechtips.com/topic/621656-need-help-with-c/#findComment-8020545
