I have e5300 + 2 gb of ram  and a hd 7850 and i want to upgrade my choices will be adding a 4 gb of ram or buy a core 2 due e8400 or some thing like that  i am using it for gaming but i do not care about resolution and setting all what i care about is frame rat please help  and sorry if my English is bad
https://linustechtips.com/topic/621591-help/
Your English is great!
   What kinds of games would you be playing specifically? And what is your upgrading budget? I'd recommend going processor first then RAM in most cases but that may change depending on your answers.
  Christian
Use the following style specs in your sig to spread the LTT revolution!
Rig Specs:
Screeninator: Gigabyte GeForce GTX960
Powermathingy: Corsair CX600W
Stickiminator: 2x G.Skill ARES 4GB DDR3-1866
Procrastinator: AMD FX-8350 @4.1GHz 1.3V
Holdametalicizor: DIYPC Gamemax-BK
Noisoundacreator: Cyber Acoustics CA-3072 (loudamagargle) Onn Wireless FM Radio Headset (earamagargle)
Attachamathingy: ASRock 990FX Extreme9
Remembrerthing: Western Digital 1TB Blue, Western Digital 40GB Blue
Flat-Colorful-Thing: Acer K272HL
See-A-Move-O: Logitech Hyperion Fury G402
ButtonBoard: Cooler Master CMSTORM Devastator Blue
Talkamagargle: Blue Snowball Ice
https://linustechtips.com/topic/621591-help/#findComment-8017609
thank u  i will play racing games and fps games like cod , bf and moh may be gta5
https://linustechtips.com/topic/621591-help/#findComment-8017621
GTA 5 and newer FPS games might be hard to run. What's your budget?
  Christian
Rig Specs:
https://linustechtips.com/topic/621591-help/#findComment-8017623
So you already spent $75? I don't know what $25 will get you in the range of processors. Probably just save up is all I can say to get maybe a quad-core like a Q6600.
  Christian
Rig Specs:
https://linustechtips.com/topic/621591-help/#findComment-8017644
Get a q6600 and more RAM
But you would be better of saving up for a better MB and CPU
If you want budget go with AM3+ or an Athlon X4 860k
https://linustechtips.com/topic/621591-help/#findComment-8017656
