So i want to build a gaming PC to use for myself, so here is what i tought off
- Case
 Cooler Master Pro 5
- Power Supply
 Corsair RMi Series 850W
- CPU Cooler
 Corsair Hydro Series H100i V2
- Case Cooler
 Corsair AF120
- Motherboard
Asus X99 Deluxe
- Processor
 Intel Core i7-5820K
- GPU
 Zotac GTX 1070 AMP EXTREME
- RAM
 Corsair Dominator 16GB ( 2x8 GB ) PC25600
- SSD
 Samsung 850 Pro 256 GB
- HDD
 WD 3 TB Black
so what do you guys think about it ?
https://linustechtips.com/topic/621561-first-gaming-pc-build/
6700k sometimes performs better in games because most value clock speed more than cores...
"AMD is bringing DDR5 to the mainstream with their all new FX 8450 and FX 9690 Zen processors. Check out the link in the video description to learn more."
  • CPU
    Intel Core i5 4690K
  • Motherboard
    MSI Z87-I Mini-ITX
  • RAM
    16gb Corsair Vengeance DDR3-1600
  • GPU
  • CHANGING
  • Case
  • BitFenix Comrade Window Black/
  • Corsair 250D
  • Storage
    Hectron X1 60gb SSD "The China", Hitachi 500gb 7200rpm
  • PSU
    Corsair TX650
  • Cooling
    Hyper TX3
  • Keyboard
    AULA F2012 Mechanical
https://linustechtips.com/topic/621561-first-gaming-pc-build/#findComment-8017383
Well, including your monitor, I had to be pretty careless about where I threw your 3500 bucks around in order to reach budget. In an X99 system, here Is what I came up with. Everything in this build is bigger, better, or faster than your original post. and consumes your 3500 budget. If you have shipping fees or whatever, you could always scale back to 16GB of RAM instead of 32, get a 1080 instead of 1070 SLI, and get a standard SSD instead of a fast m.2 drive in order to save money.
http://pcpartpicker.com/list/2kPjcc
If you went Skylake and Z170 you could easily afford 1080 SLI on that budget. and I don't know what you've seen about the 6700k that makes you think it would be obsolete in 5-6 years. I mean, if in 5-6 years you plan to be doing professional grade computer applications, then sure, that's maybe possible. but a well overclocked 6700k is never going to give you any issues in gaming and light-moderate editing/rendering workloads, not until the day it suddenly doesn't work anymore that is.
If for some reason none of this appeals to you, or things are way more expensive where you are than I've understood, then my only recommendations for your original build is to get 4x4 kit of ram instead of 2x8 for X99 (typically works better/slightly faster), and get 1080 since you can probably afford it.
https://linustechtips.com/topic/621561-first-gaming-pc-build/#findComment-8017563
