So here is my situation.  I have windows 7 on a bootable USB. It shows up on my BiOS and i can access it on my computer to see the files. However, when I try to boot with it, it says to insert bootable media? I have a new SSD that I'm trying to install it on. ;w; Please help.
Moist
https://linustechtips.com/topic/621450-usb-boot-drive-wont-work/
Is it a skylake moba? If so you have to patch the software on the board (look for instructions through your moba manufacturer for more info) to get it working since intel decided to drop support I'm sure at microsoft's request.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/621450-usb-boot-drive-wont-work/#findComment-8016109
1 minute ago, Kenji the Uke said:
Nope =w= Its z77
Hmmm that is odd, I'm assuming a usb 2.0 port is what you are using, correct?
https://linustechtips.com/topic/621450-usb-boot-drive-wont-work/#findComment-8016126
