If anyone has some spare time and wants to assist in planning out a new build with $1000 CDN it would be appreciated.
Checklist:
DDR4, ATX board
Mastercase Pro 5 (I know it's pricey)
RX 480
CPU (I've only ever had AMD, but if Intel is the way to go (even though they are leaving the CPU game) then go for it)
atleast 8GB RAM, pref 16
no CPU cooler or fans needed (have these)
Gaming (obviously) with possible rendering.
https://linustechtips.com/topic/621063-any-help/
intel isn't completely abandoning the pc market, not yet at least, but it can't expect the pc market to support it when it's profits from it are dwindling. But unless AMDs zen architecture comes along and really competes with intels processors intel has no real need to keep improving especially since smaller architectures are more difficult. Take a look at https://ca.pcpartpicker.com and see what you can make to fit your budget, but the 480 and that case eat up half your budget and intel cpu would eat half of whats left and you don't mention if you need drives or a power supply which would really make it a tight budget, but if you want ddr4 from what I can tell you need intel
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/621063-any-help/#findComment-8012071
@Mikius10001 Its going to be one of the other.  The case and GPU make the budget hard without going to some REALLY old hardware.
AMD FX 6300 - 135 CDN
Asus 970 Pro Gaming - 157 CDN
Kingston HyperX 16GB DDR3 1866mhz - 84.50 CDN
Sapphire RX480 - 410 CDN
EVGA 600B PSU - 72.50 CDN
WD Blue 1TB 7200rpm HD - 68.50 CDN
Based off Amazon.ca's pricing its 927 bucks, No case. The CM Mastercase Pro 5 is too expensive for your budget.
I'm not an AMD person. Never built with their stuff at all. This is what I could find that fit the OP's budget. Someone else could probably do better, but it's roughly 760 US or 1000 CDN.
https://linustechtips.com/topic/621063-any-help/#findComment-8012161
I tried to keep it under 1000...but as a fellow Canuck I know it's hard as fuck to do...the rx 480 4gb is 259.99 from newegg.ca when it's in stock... Other than that this should do you well brother.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($304.55 @ Vuugo)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard  ($115.50 @ Vuugo)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($43.99 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.53 @ Vuugo)
Video Card: Sapphire Radeon RX 480 4GB Video Card  ($259.99)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($157.99 @ PC Canada)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($102.98 @ DirectCanada)
Total: $1044.53
Generated by PCPartPicker 2016-07-04 22:12 EDT-0400
https://linustechtips.com/topic/621063-any-help/#findComment-8012231
