Hi guys I have a budget of £625 and i want the following :
I7-4790k
Gtx 960
Stock cpu cooler
8gb ram
1tb hard drive
I a going to be playing flight sims such as P3d
If anyone can make me this on UK pc part picker that would massively helpful
Many thanks
Joe!c
https://linustechtips.com/topic/620316-pc-build-help/
Here you go. I swapped your CPU from the i7 4790K to the i5 6500 since you don't really need a i7 4790K based on the games you are playing and there is no monitor included in this build. You could get an R7 360 if you want to save £50 and get your OS from kinguin.net to save £50.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£170.96 @ More Computers)
Motherboard: Asus H110M-PLUS Micro ATX LGA1151 Motherboard  (£54.77 @ Amazon UK)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR4-2400 Memory  (£24.99 @ Amazon UK)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  (£47.96 @ Amazon UK)
Storage: Seagate 1TB 3.5" 7200RPM Internal Hard Drive  (£50.58 @ More Computers)
Video Card: MSI GeForce GTX 960 2GB Video Card  (£139.99 @ Overclockers.co.uk)
Case: Rosewill R363-M-BK MicroATX Mid Tower Case w/400W Power Supply  (£54.99 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (£71.98 @ CCL Computers)
Total: £616.22
Generated by PCPartPicker 2016-07-03 15:51 BST+0100
https://linustechtips.com/topic/620316-pc-build-help/#findComment-8004393
Total: £616.22
That psu looks like a fire hazard.
https://linustechtips.com/topic/620316-pc-build-help/#findComment-8004551
