Ok so i just built a new pc and sometimes it just crashes,sometimes im gaming others im not,sometimes the GPU fan revs up sometimes it doesnt.And i have to reboot.
case NZXT H440W NE
motherboard Asus Maximus VIII Formula
CPU Intel Core i7 6700K 4.0GHz
RAM G.Skill Ripjaws 4 Blue DDR4 PC20000MHz 32g
water cooler NZXT Kraken X61
GPU Gigabyte GeForce GTX 1080 Founders Edition
power supply EVGA SuperNOVA G1 650W
hard drives,500G SSD,SEAGATE 8T,SEAGATE 3T,SEAGATE 1T.
Any help would be greatly appreciated.
https://linustechtips.com/topic/619701-can-someone-help-me-pleasegpu-problems/
Any errors codes? Is it blue screening? Or is it just turning off and going to a blank monitor with no warning or errors?
What are your temperatures like? When I accidently overheated my 5820k a dozen times because my cooler was hooked up wrong, It would just turn off for me, no warning or errors (thank you for temperature sensors the ability to shut itself off!).
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
Sounds like an unstable overclock. Is anything in your system running beyond its rated specs? (this includes memory running beyond 2133MHz)
If the answer to this is "yes", make everything run at its default rated specs and speeds. see if the problem persists.
If the answer is "no" make sure all your drivers, and bios is up to date.
33 minutes ago, alucard nz said:
no blue screen or errors just gos black. im using open hardware moniter and it says my GPU core is 24C and is running 139MHz. il post a screen shot.
What temps under load?
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
