Why does the WAN show still only use max 128kbps audio?
- It's a talkshow, anyone listening to it in podcast fashion (audio only) will suffer... in fact most audio listeners suffer
- They dedicate 3500kbps (as seen at steam[0] in the screenshot) to the video, so why not spare a bit extra for 192kbps audio?
- They have their expensive AF mic, but it is bottlenecked by the low audio bitrate!
LTT, pls fix.
If you found my post helpful make sure to press the "Like This" Button  ;)
https://linustechtips.com/topic/619595-wan-show-audio-quality/
LTT, pls fix.
The mic they use now is kinda a average at best mic, I've been complaining about the audio forever.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/619595-wan-show-audio-quality/#findComment-7996915
This and many other things would get better if they would invest more on whole setup. Like getting producer and real dedicated setup. Or setup with simple connections between devices.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/619595-wan-show-audio-quality/#findComment-8000236
