I recently purchased a Coolermaster Megaflow 200mm fan for my BitFenix Prodigy to replace the 140mm stock fan for intake. Mainly for noise reasons.
It worked fine, but the rattling started about a week ago and got progressively worse. It rattles a ton on a cold boot, it gets quieter after a while and I can only hear it if I put my ear up to the case. Perhaps I'm being pedantic, but it gets super annoying after a while and leads me to believe it's only going to get worse. I could get another one, but reviews I keep seeing basically say the same thing (At least the negative ones). I was considering getting a BitFenix Spectre Pro (200mm) because BitFenix case + BitFenix fan = a good fit. Right? Well all the reviews are hit or miss.
My question is, do you guys have a 200mm you'd recommend, or do you recommend just getting a couple 140mm fans for intake? I'm open to ideas, I'm not super annoyed by the slightest noise, but since my computer's on my desk, I prefer it to be as quiet as possible. The Prodigy is full of holes so it's hard to make it completely silent. I just want good air flow and for it to be pretty quiet.
Thanks for any feedback!
https://linustechtips.com/topic/619573-intake-fan-question/
To answer your question, look at the fans CFM and advertised noise and do a CFM:Noise ratio. Though with two fans, I don't know how the acoustics add together, but give it a few dB above what the advertised noise is.
https://linustechtips.com/topic/619573-intake-fan-question/#findComment-7996667
If you are planning to use 2 fans vs 1 big one you could try the Noctua NF-F12 although they are 120mm there are very quiet (I don't personally own them BUT linus has recommended them in pretty much every video possible) but they do cost a little more then other fans.
https://linustechtips.com/topic/619573-intake-fan-question/#findComment-7997581
F12s are not good as case fans, excellent rad fans though.
Have 2 bitfenix spectre pros in my build, pretty near silent at ~700 rpm, can get pretty loud at full speed for silence freaks, but I have 2 kids so I could run them full speed and it wouldn't be that bad
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/619573-intake-fan-question/#findComment-7997823
Dual 140mm. Or even 120mm if they're good. Computer fans do not scale well in performance with diameter because the thickness stays the same at 25mm.
Get a fan with a quality bearing rated to 150,000 hrs+. Chances are that coolermaster has a crummy sleeve bearing that can't handle the weight of the 200mm impeller.
https://linustechtips.com/topic/619573-intake-fan-question/#findComment-7998052
Okay, thank you.
I have an NF-F12 on my Hyper 212 Evo.
They're nice fans, $20 each though. I think I paid $16 for my 200mm fan. I was considering getting Phanteks or be quiet! ones, I trust Noctua is quiet, but $37 for two 120mm vs $30 for two 140mm fans for slightly better cooling isn't worth it for me.
I was considering getting the 200mm Spectre Pro, but it seems really hit or miss.
I heard the Antec TwoCool 140mm are good, I'm just trying to find something reputable. It seems like no matter where I look people say something different.
https://linustechtips.com/topic/619573-intake-fan-question/#findComment-7999110
