I am getting really frustrated with fan xpert 3 but I am sure it is user error. I have a Phanteks Enthoo Luxe case, Asus Z170 deluxe mobo and an enermax cpu cooler. The enermax cooler is plugged into the cpu_fan header and the chassis fan where all the fans hook up in the back of the case is hooked up to cha_fan4 header. When I go into fan xpert 3 and have it try to show me where all the fan locations are, everytime I silence all fans it always shuts down every fan except the cpu fan. What am I doing wrong??? I should note that I can change the fan speeds with the app.
https://linustechtips.com/topic/619106-help-with-fan-expert-3/
Make sure your not setting your speed too low to the point where the fans aren't capable of starting, there is also an auto-stop function if you set it below that rate. Also make sure your headers are setup appropriately for 3 pin DC voltage control and 4 Pin PWM for the fans that are connected.
https://linustechtips.com/topic/619106-help-with-fan-expert-3/#findComment-7991372
Can you expand upon this a little more or point me in the right direction where I can learn more? All of my fan connections are 3 pin. Is this change something I do in the BIOS?
https://linustechtips.com/topic/619106-help-with-fan-expert-3/#findComment-7991384
Yes that needs to be configured in the BIOS as DC voltage control if all of your fans are 3 pin, but that being said you shouldn't have been able to control any fans if the headers were all defaulted to PWM.
https://linustechtips.com/topic/619106-help-with-fan-expert-3/#findComment-7991404
