saphire radeon hd 7870 problems... AGAIN
Solved by Levent,
im using version 13.1
i had it overclocked, restored it to stock, just downclocked it to 1003 on the core and 1200 on the memory, should i try a benchmark and see whats is going on?
my psu is a corsair 600m
my motherboard is not even a half year old (bought it in july `13)
and there is your problem i assume you are using 13.1WHQL (old release) upgrade to 13.9 and see if it helps (which it does for me)
this is me running 13.1WHQL like 9 months ago
http://imgur.com/wqIEckw (check the time of upload)
