Hi,
I recently got myself a laptop but I have noticed one problem. By default, the pictures, videos and music is all stored in the C: drive. However, I would like to keep those files on my harddrive instead of the ssd. If I open explorer, my music and videos on the "this pc" overview to the left are changed so that the locations are changed to new folders in my D: drive. However, microsoft onedrive has control over my documents ad pictures tabs on "this pc". I would like to link my pictures with the shortcut on "this pc", but it wont work as the shortcut is somehow reserved for onedrive.
Thanks for the feedback.
Desktop: Processor - Intel Core i7 5820K   Motherboard - Gigabyte GA-X99-UD3   RAM - Crucial Ballistix Sport 16GB 2400MHz DDR4   GPU - Gigabyte GeForce 980 Ti G1 Gaming 6GB Case - Fractal Design R4 Window   Storage - x1 WD Green 1TB, x1 WD Green 2TB, x1 Samsung 850EVO 120GB, x1 Kingston SSDNow 120GB  PSU - Cooler Master B700 (700W)   Displays - x1 Dell E2214H, x2 Dell 1908FP-BLK   Cooling - Noctua NH-D14 SE2011
Keyboard - Razer Blackwidow Expert 2014   Mouse - Razer Deathaddder 2013   Speakers - Logitech Z906 5.1 OS - Windows 10 Pro   Headphones - Steelseries 9H, Sennheiser Momentum
https://linustechtips.com/topic/618915-need-help-in-explorer/
2 minutes ago, mathmeister said:
Yes, I knw how to change the location. However, documents and pictures dont let me change the location as I dont have access. Im the owner of this PC.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989212
Right click the library (pictures, etc) and go to Properties. In the Location tab, you can direct the library to a folder of your choosing.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989218
Yes. I know. But it wont let me change as the shortcuts are linked to onedrive.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989222
Have you tried breaking the link before changing the location?
Moved to Windows.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989226
Moved to Windows.
Thats my question. How to I break the link between onedrive and the "this pc" shortcut? I am currently unable to change the location.
Thanks
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989238
Unlink the Onedrive folder.https://support.microsoft.com/en-us/instantanswers/346c0dc9-68fb-4189-9674-8011c670c3de/change-the-location-of-your-onedrive-folder
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989248
4 minutes ago, WoodenMarker said:
Now the the this pc shortcuts show an error message with C:\users\felix\onedrive is not available, has been moved or deleted etc.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989288
Moved to Windows.
I got it fixed, thanks for the help.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989358
Can you change the location now? You can link the drive again afterwards.
https://linustechtips.com/topic/618915-need-help-in-explorer/#findComment-7989359
