Hi everyone!
Not sure if posted in the correct place but here we go,
Built a PC 2 years ago, it is freezing since day 1.
Tried lots of troubleshooting
What happens: Suddenly, high load or starting up or low load, anytime unexpectedly. Can't hear anything, mouse cursor stops, pc screen just freezes like you pause a video and keyboard doesn't light CapsLock or Numlock lights.
What I tried:
----------------Software-----------------
FORMATTED THE PC! (factory reset, reinstall of win7 etc.)
Deleted a TEMP file with 135GB in it
Changed startup programs
Ran whole pc scan
Some registry edits
IF IT IS SOFTWARE RELEATED, may need to update MOBO bios settings, problem here, if it freezes during this, I am f... up so bad, btw MOBO warranty expired
--------------------------Hardware----------------
complete changes of pc part update history:
GPU: Gigabyte R9 270X 2GB OC (1year later) MSI R9 390 (months later) MSI R9 390 (RMA) (reaches max 85°C)
CPU:INTEL i7 3770K for 2 years, haven't changed anything, STOCK cooler
MOBO: ASUS z77-a, haven't changed
RAM: Had 2x: https://uk.hardware.info/product/172601/kingston-hyperx-black-8gb-ddr3-1600-cl9-kit/photos, than tried troubleshooting and tried with 1 ramsticks, changed one of them to: https://us.hardware.info/product/213365/kingston-hyperx-fury-blue-8gb-ddr3-1600-cl10-kit
HDD: Have 2x WDC WD10EZEX-00BN5A0 added WDC WD10EURX-63FH1Y0
IF IT IS HARDWARE RELEATED, I think the problem is P S U, maybe it doesn't deliver the POWER? I plan to buy corsair rm750x
https://linustechtips.com/topic/618679-pc-freeze-help-please/
Wow, that's a though one. Well have you tried reinstalling WIndows? Maybe it's a software problem that can't be fixed by editing or software.
ASUS ROG Strix B550-F + AMD Ryzen 5800X3D; ASUS 6800XT TUF; 16GB G.Skill TridentZ 3600; bequiet! Dark Power 13 850W; Samsung 860 Pro M.2 2TB; PHANTEKS Evolve X
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986409
2 minutes ago, KYZED said:
done that too, noperino :(
Okay then it's a hardware problem. Since it's not load related it's rather unlikely to be the PSU. It's rather a storage problem, so CPU (Cache), RAM or HDD. Now you have tried a new RAM-Stick with the old ones taken out, is that correct?
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986427
Is your HDD speed  fast enough? Since i upgraded to my SSD my pc works a lot (i mean a lot) faster. Also multitasking with anti-virus programs running etc. goes a lot faster without any stutters. I had that before when i was doing everything from my HDD
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986441
3 minutes ago, KYZED said:
Yeah,
I formatted a year ago, but befor that it was freezing like how it still does,
Haven't changed cpu
changed gpu 3 times
maybe PSU is low quality? CM 600W thunderbolt
Added 1HDD like I said and tried rams 1 by 1
If your PC was still freezing with the R9 270x which this PSU can run without a problem then it's not the PSU.
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986447
4 minutes ago, KYZED said:
Yeah,
Haven't changed cpu
changed gpu 3 times
Did you test the sticks for errors with Memtest86 or the inbuilt Windows Memory diagnostic tool?
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986450
Yeah,
Haven't changed cpu
changed gpu 3 times
Yeah it's not the best PSU but it's still very unlikely. If the PSU wouldn't deliver enough power it would only freeze under load and you'd see artifacts before that. Since you have 3 HDDs did you try installing Windows on another one? Also did you check the RAM 1 by 1 in every slot? Maybe it's not the RAM but rather a slot? Also is anything overclocked in your system? To what Speed is your RAM set?
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986452
fast enough? the model is there
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986453
no overclocks, don't think something is wrong with hdd, what about mobo bios update?? as it is one of my major questions
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986459
A slow HDD still wouldn't cause the PC to freeze, only a broken one ...
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986460
Don't see that changing anything. Either the BIOS detects your hardware or not, there isn't really anythíng in between. Since nothing is overclocked I'm still pretty sure it's the HDD or RAM.
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986472
ok whats the fix for hdd then?
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986478
there are 4 slots for ram, in manual it says it is better to stick to blue ones
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986484
Go to the Western Digital homepage, download "Data Lifeguard Diagnostic" and check your HDD.
Not if one of them or worse the complete channel is broken. Just take ONE of your RAM sticks and try to put it in another Slot. Only use this ONE stick. Try every slot if it sill freezes, take another stick and do the same thing. If it's still freezing it's not the RAM.
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986497
okay stay here mate, I'll update you! thanks alot btw!
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986510
okay HDD smart status PASS, what about the other options?
Extended Test
Quick Test
View Test Results
Write Zeros
what do I need to do now?
PC haven't froze for 4 hours low browse load btw :)
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986534
Extended Test
Quick Test
View Test Results
Write Zeros
Okay that's good, try an extended Test, if it still passes, try the RAM either like I said it, or with Memtest86 like @MarthiniL suggested.
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986556
Extended Test
Quick Test
View Test Results
Write Zeros
Have you already tried installing Windows to another HDD (like suggested already before)? I've similar issue and it was HDD related. Needless to say that said HDD since almost died.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986558
probably insatlled on the same one again, format won't work probalby :/ it didnt
https://linustechtips.com/topic/618679-pc-freeze-help-please/#findComment-7986565
