  1. - Intel® Core™ i3-6100 Processor (3M Cache, 3.70 GHz) (4CPUs)
    - CPU Last 6th Generation Series 2016
    - Mainboard:MSI H110M-PRO VH(1151)
    - RAM : 8GB DDR4
    - HDD : 1,000GB
    - VGA 1 : Intel Graphic HD upto 1.7GB
    - VGA 2 : Nvidia Geforce GTX 750ti 2GB
    - Optical Drive: DvD-RW/CD-RW
  2. - Intel® Core™ i7-4790 Processor
    (8M Cache, up to 4.00 GHz) (8CPUs)
    - CPU Last 4th Generation Series 2015
    - Mainboard: ASUS H81M -K (1150)
    - RAM : 8GB DDR3
    - HDD : 1,000GB
    - VGA: Intel Graphic HD 4400 upto 1.7GB
    - VGA: Nvidia Quadro GTX750Ti 2GB GDD
** These 2 systems available in my local and the (1)system is about $100 cheaper than the (2)system , any advice which one should I get and why ? Im all new to this, pls help !!
https://linustechtips.com/topic/618621-need-help/
I would recommend the 2nd system as that bump up to a i7 is defiantly worth it and there isnt much difference between ddr3  and 4...
~ Main Rig ~
- Ryzen 9 3950X 16 Core 32 Threads - EVGA 3090 KINGPIN HYBRID - 32GB DDR4 3600mhz -
- 6TB SSD Array + 2TB MP600 NVME Gen4 Boot -
- Gigabyte X570 AORUS MASTER - Lian li O11 Dynamic XL - NZXT Kraken X73 + 16 Noctua NF-A12x25 Fans -
~ Accessories ~
- Logitech G915 + G903 - LG C9 OLED PG279Q 27'' [1440p 165hz G-Sync] +  PG27AQ27'' [4k 60hz G-Sync] -
2x 1440p Portrait 25'' Dell - DT 990 Pro Headphones -
~ Servers ~
- 100TB NAS + Server's w/ 6700k - 32 + 64GB Ram - NVME Boot - Gigabit Unlimited Fiber -
https://linustechtips.com/topic/618621-need-help/#findComment-7985871
    - RAM : 8GB DDR4
    - HDD : 1,000GB
    - RAM : 8GB DDR3
    - HDD : 1,000GB
Don't get a pre built. Building your own is cheaper and allowed a for much higher species systems. Also, it's easier than you think.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/618621-need-help/#findComment-7985891
is it tha much different ? isn't those DDR4 some how make up for the gasp between i3-6100 and i7-4790 ??
https://linustechtips.com/topic/618621-need-help/#findComment-7985955
No, sadly it doesn't work as though you can add all the numbers together and get the performance of a pc... The difference between ddr3 and ddr4 is pretty much 0 for most things like gaming... But the difference between a i3 and a i7 is massive, since you have in many ways over double the computational power for cpu related things.
~ Main Rig ~
~ Accessories ~
~ Servers ~
https://linustechtips.com/topic/618621-need-help/#findComment-7985963
it's really hard to get a market price hardware at my local , most of them are like 40% overprice and Im in Asia , shipping from Amazon or Ebay cost like 40-89$.
https://linustechtips.com/topic/618621-need-help/#findComment-7985964
what if the system(1) replace with i5-6500 and GTX950 instead ?
https://linustechtips.com/topic/618621-need-help/#findComment-7985979
Then it would probably depend on how much money you wanted to spend... I would personally go with the 2nd still since it has a more powerful gpu which would make the biggest difference with the better cpu as a bonus
~ Main Rig ~
~ Accessories ~
~ Servers ~
https://linustechtips.com/topic/618621-need-help/#findComment-7985987
more powerful GPU ? u're saying GTX 750Ti is better than GTX950 ?
https://linustechtips.com/topic/618621-need-help/#findComment-7985994
Ah no! Sorry I misread that for a 750... No certainly go for the first if that's the case :)
~ Main Rig ~
~ Accessories ~
~ Servers ~
https://linustechtips.com/topic/618621-need-help/#findComment-7985999
well. thank for this . well what about monitor ? any recommendation ? should I get TN panel or IPS panel ? I mostly play game like World of Warcraft,Leauge of Legend, and some PS3-4 games . Im looking for under 200$ price range.
https://linustechtips.com/topic/618621-need-help/#findComment-7986042
This is the monitor I'm planning on getting soon, not sure what price it is for you though...
http://www.aocmonitorap.com/v2015/nz/product_display.php?id=5074
I would recommend always trying to go for IPS since the panel does colors better...
~ Main Rig ~
~ Accessories ~
~ Servers ~
https://linustechtips.com/topic/618621-need-help/#findComment-7986052
it's nice , sadly it doesn't even available in my local .. What do u think about these monitor ?
  1. Dell - S2316H
  2. Dell - P1914S
  3. ASUS VX239H
  4. AOC I2381FH
  5. BENQ GL2460
  6. ACER S236HLtmjj
  7. ACER G247HLbid
all of these are around the same price in my local...
https://linustechtips.com/topic/618621-need-help/#findComment-7986096
  1. Dell - S2316H
  2. Dell - P1914S
  3. ASUS VX239H
  4. AOC I2381FH
  5. BENQ GL2460
  6. ACER S236HLtmjj
  7. ACER G247HLbid
They all look decent, its more of a personal choice... I like the look of the asus, dell and aoc but that's mainly because they don't have a very large bezel... I would just pick the cheapest one of the lot that looks the nicest to you :) A few things to look at is the response rate (Though all of those seem to be under 10ms so their basically all the same) and the screen finish, (glossy/matte) I personally like the matte finish over glossy but again it comes down to personal preference :) Just pick the one that you like the most
~ Main Rig ~
~ Accessories ~
~ Servers ~
https://linustechtips.com/topic/618621-need-help/#findComment-7986107
