How to test a second hand GPU?
Solved by Liltrekkie,
Furmark, 1080p (or native monitor resolution), full screen, no MSAA, do the regular stress test, not the extreme burn in. run for like 20 minutes. or have a beer (or soda if youre under age)
If you have tomb raider those have a bench mark thing, MSI afterburner has a stress tester though I've never used it.
Firestrike will put it through its paces either, however again never used it.
Any of the 3dmark platforms.
Or, answer age old question, will it run crysis?
