This is my first gaming 1440p PC build, I have the parts and done a lot of research and even based it close to an existing build by a popular youtuber, however i have changed mine a little so it needs revising before i purchase it so any comments on bottle-necking / compatibility would be great.
Parts list:
Case:                          NZXT H440
GPU:                           ASUS GTX1070 STRIX
CPU:                           i7 4770
CPU cooler:               Phanteks PH-TC12DX
Motherboard:             Asus Z170 Pro Motherboard
RAM:                           HyperX FURY 16 GB
PSU:                            Corsair CP-9020097-UK VS550 ATX/EPS Vs Series 80 Plus
HD:                              WD 1TB
SSD:                           Samsung 850 EVO 500 GB 2.5 inch
Monitor:                       Acer XB270HUD
Montior cable:            CSL - 1m (metre) Ultra HD 4K Displayport 1.2v (DP) on Displayport 1.2v
I also thin i may need:    SilverStone SST-PP07-PCIW; PCI-8pin to PCIE-6+2pin_250mm
3 minutes ago, Richdogbignob said:
This is my first gaming PC build, I have the parts and done a lot of research and even based it close to an existing build by a popular youtuber, however i have changed mine a little so it needs revising before i purchase it so any comments on bottle-necking / compatibility would be great.
Parts list:
Case:                          NZXT H440
CPU:                           i7 4770
Motherboard:             MSI Z97S SLI KRAIT EDITION
HD:                              WD 1TB
I would get a 4790k instead or a 4790 and would get a MSI 1070 but the gpu is personal preference
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
19 minutes ago, Richdogbignob said:
Is there a difference between the 4770 and 4790, and worth the upgrade??
the 4790 is known for better temeratures also probably wont need pci cable
