Hey guys,
I may have a problem with my pump, it seems as if when starting are running with some air in the loop, but then after it gets used a bit (5-10 min) the sound disappears, I have not been able to find any leaks or such on the pump/cooler and it runs at the same temps as it has always done.
Specs
  • AMD Phenom II 965 @ 3,4 GHz(with Corsair H60 cooler)
  • GIGABYTE GA-MA770T-UD3 (rev. 1.4)
  • 4 gb kingston, and 8 gb kingston hyperx blu @ 1333 MHz
  • Gigabyte GTX 660ti OC edition @stock
  • 1 TB Samsung spinpoint HDD
  • 256 GB Plextor MP5-Pro SSD
  • Optical drive no name
  • cooler master elite 430 black
  • ASUS Xonar DGX
https://linustechtips.com/topic/6164-corsair-h60-problem/
There is always a little air in the loop. Most AiO will make the old "buble" noise after being off for a while and will quiet down after being run for a bit. This is normal. If you didn't notice before maybe you were just lucky then with your bubbles? :)
My Antec Khuler 920 would make an aweful racket after being off for any amount of time for the first few minutes while everything got properly circulated.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/6164-corsair-h60-problem/#findComment-68065
well I guess it's all right then' date=' isn't it bad for the pump not to be under water the whole time, like the swifttech h220 Linus just tested?[/quote']
It's just working out some bubbles. It's fine. The issue is if your pump runs with zero liquid - that is bad. :)
https://linustechtips.com/topic/6164-corsair-h60-problem/#findComment-68446
