System temps while gaming
Go to solution Solved by don_svetlio,
1 minute ago, Haidar said:
That's true, but on Intel ark site, it says the max temperature is 60c, thermal throttling starts at 100c
60*C is very low. It should be 72*C for the die (recommended) and 100*C is thermal shutdown
Hello everyone, I just finished my first PC build, used to to be a laptop user for 5 years, then I got sick of the low end graphics and resolution
that's why I choosed desktop gaming, my new PC : Intel core i3 6100, 8 gigs of ddr 4 ram, mini itx Asus h110i,amd Radeon r7 360 from Asus,seasonic g450 gold, ssd 120gb, hdd 500gb, all of that in a 10 years old PC case ( I will buy the define nano s next month ), my question is: is it normal for my CPU to reach 60c while gaming, and my gpu reaches 70c ?, I'm using stock Intel cooler, and thermal paste, and I have only one case fan near the CPU as an intake under the psu ( top mounted psu )
https://linustechtips.com/topic/616361-system-temps-while-gaming/
It's completely fine.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
All normal
3 minutes ago, ContraHacker said:
Oh, that's normal? I have the same CPU and under gaming, it never hits 50+ degree Celsius.
What kind of game though? That is the most important variable
When I play bf4 for example the temps lock at 50, but in far cry 4 it locks at 60c, are you using the stock cooler ?
That's normal - each game puts a different load on components.
The GPU temp is normal.
The CPU temp is normal for a stock Intel cooler. If you want a bit better temps and less noise, get a small cooler such as a CM Hyper 101/T4/103 or similar.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
