CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.88 @ OutletPC)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($25.99 @ Newegg)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  ($49.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($44.95 @ Amazon)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($33.99 @ SuperBiiz)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($55.99 @ Amazon)
Other: Rx 480 ($199.99)
Total: $693.77
Generated by PCPartPicker 2016-06-24 21:46 EDT-0400
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957504
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($197.99 @ SuperBiiz)
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard  ($64.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($52.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($92.00 @ B&H)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($67.99 @ Newegg)
Case: Rosewill FBM-01 MicroATX Mini Tower Case  ($29.99 @ Amazon)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($28.00)
Other: AMD RX 480 8GB ($250.00)
Total: $844.94
Generated by PCPartPicker 2016-06-24 22:00 EDT-0400
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957550
19 minutes ago, Telford said:
Thanks for the help people!
I took some of the parts from the build lists above and did a little changes - views?!??!?
http://pcpartpicker.com/list/TMhtJV
Get a board that supports ddr4, it should be only a few bucks more. Don't get the cx600, not a very good psu. Get the cx550m(better quality) instead. Wait for the rx 480 instead of getting the gtx 970.
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957733
Here are some pointers you might want to take note of:
CPU: You mentioned you are recording and editing videos am I right? If that is the case and you can squeeze in an i7 6700K for $324~ you can get the best possible time for editing. If you don't record often and do only minor editing, then go with the i5 6600K. Another note, do you plan on overclocking? If you do not or don't know how, don't get an unlocked CPU, however, don't let that discourage you.
CPU Cooler: A 212 EVO is a 'blower-style' cooler. It makes very loud sounds which can be very irritating. A Cryorig H7 is your best bet for a good cooler for $34.50.
Motherboard: You can get a better motherboard which supports DDR4 Memory (more to that later) at that price. What I would recommend is the MSI Z170-A Pro if you plan on using an unlocked CPU. If you don't plan on overclocking, you can get a H170 for a better price.
RAM: Now that DDR4 Memory is affordable, you can get 2 sticks of 8GB RAM if you are recording and editing videos.
Graphics Card + Monitor: The GTX 970 is not the best of choices now. You can get a RX 480 for the same price and better performance or if you want an NVIDIA card you can opt for a GTX 1070. If you only game at 1080p, get a 1080p monitor.
AMD CPU =/= AMD GPU. You don't need an AMD CPU to use an AMD GPU.
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957807
As far as I know, the 212 EVO is very  quiet. My dad recently upgraded to one and it's whisper quiet and performs very well. Also it is not a 'blower' style cooler. A blower would use an impeller sort of fan (not found on the 212 EVO).
The bottom is not a blower the top is.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957864
My bad then, I'm not too sure on parts :P
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957894
1 minute ago, AssassinUni said:
My bad then, I'm not to sure on parts :P
That alright! It's always good to learn these things anyway for future references!
Main System Specs:
Laptop Specs:
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Dell 2003 Mouse
https://linustechtips.com/topic/616120-entry-level-pc/#findComment-7957897
