CPU Fans
Go to solution Solved by Samppa221,
It looks like it can handle 2 fans on either side. You will need those metal things to install it did it come with an extra pair?
https://linustechtips.com/topic/615748-cpu-fans/#findComment-7953499
3 minutes ago, Mistypro said:
i've been wondering actually can i add more fans to my CPU coolers (Cryorig H7)? Coz i bought one fan extra and idk what to do with it...
The Heatsink itself can support 2 fans and 3 different configuration profiles, Push, Pull, or Push/Pull.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/615748-cpu-fans/#findComment-7953501
