8 minutes ago, DPerry918 said:
http://pcpartpicker.com/list/FQ23Fd <--- Here you go, under 1400 dollars
Much better than build from OP.
But that PSU seems like overkill.
Maybe get 650W gold? New GPUs will have less and less power draw, and I don't think OP will buy 2x titan x xD
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
2 minutes ago, DPerry918 said:
Let me know what you come up with!
So this is what I made of it:
http://pcpartpicker.com/list/4nVnnn
I changed the RAM because it looks cooler :P
This is true, I just never like to go low on power. My new build coming up is way overkill on power also but I just like having the insurance that If i ever want to add, do anything, I have the option :)
Fair enough on the Ram, again I said I was a corsair fanboy but GSKIll makes good stuff also. I would look into another case maybe if I were you. If you are set on it, then go with it. But that case seems very large, clunky, dated, and not up to standards with cable management, the trend has been going to minimal looking cases with functionality and I dont think this hits either of those haha. Just do some research, you some decent room in your budget now so you can get a very solid case like the NZXT H440 or Corsair 400C
Yea after quite some research I kinda got obsessed with the phantom 410 cuz it has decent space and cable options and it look amazing for me.
Seems solid now :)
About case ... well everything will fit in it for sure. But it's up to you if you like the looks of it xD
Define S is cool case. Bought it few days ago, because my S340 was too smal for water loop lol
WD My Cloud 4TB
Then go for it, it is YOUR build. My upcoming build im using the Lian LI PC-08. It isnt the best at cable management, def not the cheapest at 350 dollars, not the best for watercooling, but I have fallen in love with the way it looks so I stuck on it
1 minute ago, Simon771 said:
Seems solid now :)
Alright thanks guys, this really helped out. :)
