Radiator mount
Solved by airdeano,
it is not the 'ideal' location. the radiator acts as the systems reservoir. when the pump is the highest point of the liquid cooling system, any air trapped (to provide thermal expansion) will occur in the pump assembly and that is bad. air in the pump created noises, pump dry run and eventually will damage/failure the water pump.
1
2
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
play_circle_filled
Latest From ShortCircuit:
