Ive had this cpu for a time now, and i really want to overclock it, i know the risks that come with it if you do it incorrect. Ive come to this site to get some help with the process
All my specifications:
http://valid.x86.fr/j9jyjw
CPU Name
AMD FX(tm)-6300 Six-Core Processor
Threading
1 CPU - 6 Core - 6 Thread
Frequency
3792.35 MHz (17.5 * 216.71 MHz) - Uncore: 2167.1 MHz
Multiplier
Current: 17.5 / Min: 7 / Max: 20.5
Architecture
Vishera / OR-C0 Step (32 nm)
Cpuid / Ext.
F.2.0 / 15.2
IA Extensions
MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Caches
L1D : 16 KB / L2 : 2048 KB / L3 : 8192 KB
Caches Assoc.
L1D : 4-way / L2 : 16-way / L3 : 64-way
TDP / Vcore
94.99 Watts / 1.272 Volts
Type
Retail (Original Frequency : 3500 MHz)
Motherboard
Model
Asus M5A97 R2.0
Socket
Socket AM3+ (942)
North Bridge
AMD RD9x0 rev 02
South Bridge
AMD SB910/950 rev 40
BIOS
American Megatrends Inc. 2603 (06/26/2015)
Memory (RAM)
Total Size
4096 MB
Type
Dual Channel (128 bit) DDR3-SDRAM
Frequency
577.9 MHz - Ratio 3:8
Timings
11-11-11-28-27 (tCAS-tRC-tRP-tRAS-tCS)
Slot #1 Module
Corsair 2048 MB (DDR3-1337) - P/N: CM3X2G1333C9
Slot #2 Module
Graphic Card (GPU)
GPU #1 Type
AMD Radeon R9 200 Series @ 1400 MHz
GPU #1 Brand
GIGABYTE Technology
VRAM #1 Type
2048 MB @ 1500 MHz
DirectX
12.0
Storage (HDD/SSD)
Model #1
Seagate ST1000DM003-1ER162
Capacity #1
1000 GB
Display
Screen #1
Dell Computer DELL E228WFP (DELD015)
Screen #1 Spec
22 inches (55.9 cm) / 1680 x 1050 pixels @ 56-75 Hz
Miscellaneous
Windows Version
Microsoft Windows 10 (10.0) Professional 64-bit
Windows Subver.
Build 10586
CPU-Z Version
1.76.0 (64 bit)
https://linustechtips.com/topic/615344-help-with-overclocking/
