Today i was playing some H1Z1 King of the kill and i wanted to record it for my youtube channel, however with obs i noticed where theres a lot of action etc going on the game becomes pixelated, can anyone help me find the best 1080p settings to use My specs are - AMD FX-6300 / GTX 750 ti / 8gb DDR3 1866mhz ram. Or any help with settings to adjust in the game if needed would be fine :) thanks!
https://linustechtips.com/topic/615049-best-obs-settings/
There's this website I just learned about earlier today: https://obsproject.com/estimator
It should help you pick good settings :)
https://linustechtips.com/topic/615049-best-obs-settings/#findComment-7944795
