I built my first rig a couple months ago and installed a Cooler Master Hyper 212EVO.  The fan rattled a lot and made me nuts, so I've switched to a closed-loop liquid cooler: the Corsair H55.  I don't do any gaming, but I do render edited video, which takes up 100% of my CPU (an eight-core AMD FX-9590 [4.7 Ghz]) for about 20 minutes.  (I don't overclock at all.)  With the old 212, I never saw my CPU temperature get higher than 71° C, and they cooled off very quickly.  Now with the H55 loop, SpeedFan reports a CPU temperature of < 103° C.
'How has my CPU not melted?' I asked myself, so I reseated the pump with Arctic Silver 5 paste (spreading it evenly with a card) rather than the stuff that came with the H55.  And still, I'm seeing SpeedFan report over 100°.  This is corroborated with the ASRock Extreme Tuning Utility (I have an ASRock 990FX Extreme9 board).  But Core Temp and Speccy report the individual core temperatures as much, much lower.
So my question is: what gives?  Is my CPU really running at 104° C?  How has it not called all the boys to the yard because it's so hot?  And how on earth does a liquid cooler (albeit a 120 mm) run so much hotter than the heatsink?  Is the 212EVO just that awesome (despite its fan)?
https://linustechtips.com/topic/614994-accurate-cpu-temp/
Judging by AMD's website the max temp is 57 °C so if it still lives my guess would be that SpeedFan is giving the wrong temperature. Try another program and see what that says.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/614994-accurate-cpu-temp/#findComment-7944313
I've always used Speccy and HWMonitor to measure CPU temps, as well as fan speed.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/614994-accurate-cpu-temp/#findComment-7944340
So I've run a full load for 20 minutes and monitored with 7 different programs:
AIDA64 Extreme - 64° C
Core Temp - 65° C
Speccy - 65° C
CAM - 65° C
HWMonitor Pro 65.1° C
ASRock Extreme Tuning Utility - 102° C
SpeedFan - 103° C
Most of the monitoring software reports core temperature as fairly reasonable, but then AXTU and SpeedFan report abnormally high readings.  I wonder if it anything to do with the Voltage Regulator Module readings?  VRM1 is 110° C.  Why so hot?  (What exactly does the VRM do, and is it in the processor?)  The ASRock FX990 Extreme9 has 10 + 2 CPU power phases, I think.  (I don't understand much of this side of it all.)  Is that part of it?
https://linustechtips.com/topic/614994-accurate-cpu-temp/#findComment-7945922
