System info:
CPU amd athlon 760k Fblack edition with stock heat sink
MB:  GB F2A55M-S1
in general  - the MB from the BIOS says that the cpu is at 80+ degrees and the windows program performance test9.0 says its at 60 (just applied new thermal paste)
Witch one to trust?
https://linustechtips.com/topic/614794-heat-problems/
13 minutes ago, komar said:
System info:
MB:  GB F2A55M-S1
Witch one to trust?
generally the bios is most accurate but something is off here. maybe the sensor is differrant reseat your cooler
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
https://linustechtips.com/topic/614794-heat-problems/#findComment-7942183
Try picking up a low price Air cooler. A good one only runs about $25-30 and could make a world of difference.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/614794-heat-problems/#findComment-7943510
