So i have just found out my MoBo doesn't support 2400mhz ram, so now i finally think its high time i get a new one anyway as my current is simply designed for office functions rather than gaming.
i am having real trouble finding a decent model thus far.
I need:
a 1150 socket (preferably z97)
DDR3 Ram with up to 2400 mhz support up to 32gb
at least 2 pcie slots
a wealthy amount of USB 3 at the rear I/O,
Ethernet, USB 2 all your basic shiz really
ATX Form factor
Plain colour scheme (grey scale or blue, no red or green etc. sounds stupid but its important to me.)
for under 150 Euros (£130ish)
any recommendations and experience is warmly welcome with imaginary mead, thanks.
CPU: Ryzen 7 3800X 4.4GHz | GPU: RTX 3070 FE | RAM: Corsair Dominator RGB 4x8GB 3600MHz DDR4 | MoBo: ASUS Crosshair Hero VIII  | Case: Corsair 5000D AF CPU cooler: Corsair H150i CapellixPSU: Corsair RM850x |
https://linustechtips.com/topic/614575-help-me-find-a-mobo/
I need:
ATX Form factor
https://amzn.com/B00TXBP1NS
Look for one of these.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939851
I need:
ATX Form factor
The Asus Z97-A  is a great choice and costs around 150 euros.
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939857
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939858
they were on my mind a bit
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939867
Just now, DrM said:
Ive never heard of ASRock, are they good?
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939874
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939884
they make pretty good boards and one of the biggest manufacuters (besided msi, asus, and gigabyte), though ive heard their customer service is nonexistent (worse than asus even.  ive never actually had any experience with them myself though
https://linustechtips.com/topic/614575-help-me-find-a-mobo/#findComment-7939919
