Hi Everyone
i really confuse right now. I want to build gaming pc that can overclock with budget $350 for CPU, GPU, Motherboard, and Memory because i will use power supply and case from my old pc
I have plan like this :
GTX 950 Zotac AMP
AMD FX 6300
Gigabyte GA-78LMT
Is it good enough or i waste my money, help me please
Edited by fakhrulraharjo
https://linustechtips.com/topic/614138-help-please/
If you can wait for 8 days, the new rx 460/470 are coming, get those instead.
https://linustechtips.com/topic/614138-help-please/#findComment-7934939
Get this instead.
CPU: AMD Athlon X4 845 3.5GHz Quad-Core Processor  ($66.18 @ Amazon)
Motherboard: Gigabyte GA-F2A78M-HD2 Micro ATX FM2+ Motherboard  ($36.98 @ Newegg)
Memory: PNY Anarchy 8GB (1 x 8GB) DDR3-1866 Memory  ($26.98 @ Newegg)
Storage: Seagate Constellation ES 1TB 3.5" 7200RPM Internal Hard Drive  ($44.00 @ Amazon)
Case: Ultra XBlaster V2 ATX Mid Tower Case w/450W Power Supply  ($27.39 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.98 @ Newegg)
Other: Rx 460 ($100.00)
Total: $335.51
Generated by PCPartPicker 2016-06-20 20:23 EDT-0400
https://linustechtips.com/topic/614138-help-please/#findComment-7934943
11 minutes ago, herman mcpootis said:
Get this instead.
Total: $335.51
i cant find the mobo in my country, dou you have another suggestion?
https://linustechtips.com/topic/614138-help-please/#findComment-7934983
just get the cheapest fm2+ mobo with the features you need. what model of psu do you have?
https://linustechtips.com/topic/614138-help-please/#findComment-7935005
34 minutes ago, fakhrulraharjo said:
Hi Everyone
GTX 950 Zotac AMP
AMD FX 6300
Gigabyte GA-78LMT
Well depends what the power supply was from your old PC...
Also storage?
BTW, it's really not worth it to build a $350 gaming PC. Save your money until you can do at least $450 or $500. It's worth it.
https://linustechtips.com/topic/614138-help-please/#findComment-7935023
Also storage?
i just got a bad news that my old power supply was broken
so i think i will build a new one with $500 budget, what part u thing i should buy?
https://linustechtips.com/topic/614138-help-please/#findComment-7940125
https://linustechtips.com/topic/614138-help-please/#findComment-7940131
