Guys if i have a air cooler on my cpu is it recommended for me to put 2 140mm top exhaust fans.
My case is a 200r
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/613794-fan-placement/
1 minute ago, huilun02 said:
Set the rear fan to intake, and air cooler to blow upwards.
What if i remove the rear fan? What about RAM clearance
Build
https://linustechtips.com/topic/613794-fan-placement/#findComment-7930924
Put your RAM on the farther set of slots and hope the cooler isn't fat/low enough to collide with them.
No point removing the rear fan. You'll just leave an open hole where air can freely enter/exit.
ooh ok,
Can I control the Corsair Sp series think to go that way
Build
https://linustechtips.com/topic/613794-fan-placement/#findComment-7930960
What about it?
ooh ok,
The fans blow one way. If you want them,to blow the other way, flip the fan around.
https://linustechtips.com/topic/613794-fan-placement/#findComment-7932879
