Need opinion on a case!
Go to solution Solved by SeanAngelo,
3 minutes ago, Mr.Kios said:
amazon.uk amazon.de and a greek on which is skroutz.gr
for a little bit more, you can get these
http://de.pcpartpicker.com/product/7H2rxr/phanteks-case-phec416pscbk
http://de.pcpartpicker.com/product/jrVBD3/phanteks-case-phes515pbk
Hello guys, lately i am thinking of changing my Psu a old thermaltake 700 w( which 6 years old now) to a new one which will probably be either the EVGA Supernova g2 750w or the Super Flower Leadex 750w. Given that my case is really old and not a good one too i was thinking of buying a new case and while looking i found the aero 800 and aero 1000 cases from aerocool which i though minimalistic and nice. I saw some reviews but they were not that clear and did not trusted them. So if anyone has seen this case, worked with it or knows someone that owns it, i would like some info about it. Is it any good, what disadvantages does it have and so on.
Thank you in advance.
https://linustechtips.com/topic/613488-need-opinion-on-a-case/
for that price, you can do better
http://pcpartpicker.com/product/8v38TW/phanteks-case-phec416pswbk
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7927607
2 minutes ago, Mr.Kios said:
@SeanAngelo In my country the aerocool 1000 is 67 Euro and the phanteks is 98 euros :S
which site are you looking at?
and you dont need to mention my name when quoting.
Old Rig
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7927670
Old Rig
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7927706
Enthoo Pro should be ok. Thanks a lot
no problem. glad i could help! :D
Old Rig
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7927739
Hey man, as @SeanAngelo said, go with phanteks, and the enthoo pro m is a good choice. But if you want something a little better, go with the Phanteks Enthoo Pro M Acrylic Window. It's basically the same as Entho Pro M, but with a full clear acrylic side panel instead. It looks way better.
http://de.pcpartpicker.com/product/vVwqqs/phanteks-case-phes515pabk
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7928485
yes, what he said. you can go with the full acrylic window for goodness :D @Mr.Kios
Old Rig
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7928495
On 22/6/2016 at 8:01 PM, Mr.Kios said:
@SeanAngelo @SpyingAround Thank both of you guys. The truth is that i found the acrylic one at 92 euros which seems to me like a a really good price for what i am getting. You were plenty helpful!!! Thank you again!!!
When you get the case you will be surprised by how many features you actually get for 92 euros. All kinds of small details, and the big window just makes the case even more good looking. And you are welcome :)
https://linustechtips.com/topic/613488-need-opinion-on-a-case/#findComment-7954456
