Hi everyone!
I have two mice and two keyboards on the same PC (one for gaming, the another for working).
I need to separate each of them on my PC,
Anyone can tell me how to do that, maybe with a program or a trick on the Windows OS ? (what is the best program and trick?)
And one more thing, Each mouse and key board have the different Macro settings so try hard please :ph34r:
Thanks you very much!
Hope someone with the same problem like me can see a good solution. ;)
https://linustechtips.com/topic/613371-using-multi-mice-and-keyboards/
I have seen USB hub with physical switch which turned on/disabled certain ports so you could plug in multiple M+KB then use the switch to disable the ports in the M+KB you didnt want and enable the others with different M+KB (not sure where to buy it or how it is called).
A good idea, but if i play a game or do somethings, i will not able to quick switch to the another M+KB
