Hello all.
I know the NZXT Phantom 410 can fit a 240mm rad in the top, but can one also fit in the front?
I have only been able to find a video talking about the rad clearance in the top.
I know the front has 2 120mm fan mounts, but I am not sure if the clearance is there for a rad and fans..
Thanks in advance!
https://linustechtips.com/topic/6133-nzxt-radiator-help/
