GPU upgrade help :D!
Solved by SeanAngelo,
7 minutes ago, Joey96 said:So I was looking into my first pc upgrade i've ever done!
And came across some questions regarding a upgrade to a MSI GTX 1070 Gaming
My RIG:
CPU: i5-4460 3.2GHz
PSU: FSP600-50ARN 88+ Silver 600W
I wanted to know if there will be any bottleneck because of my CPU? Would it still be worth? Or too much performance loss?
And if my PSU would be able to handle the MSI GTX 1070 Gaming?
And if there is something else i need to have before im able to replace my GTX 960? Or is it just simply plug and go?
nope, you're fine.
plug and go. might wanna change psu though, seems like its unbranded.
