I run compressed air about once a year. I just clean out the front dust filter every other week. Cleaning schedule depends on where you live and how dusty your room gets.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/612997-annual-case-cleaning/#findComment-7921996
Depending on the environment once or twice a month seems excessive. I'd say about every 6 months. Maybe every 3 if you REALLY like to have it clean or are in an environment with a lot of dust.
https://linustechtips.com/topic/612997-annual-case-cleaning/#findComment-7922001
Personally I swap one or more parts every 2-6 months. When I change a new part I blow over some of the parts but eventhough my case is open air style it doesn't get dusty at all. I don't think I've cleaned certain parts ever since I got them and with some that was almost 3 years ago.
Someone once said: "Having a rollercoaster on a PC would be epic"
So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build
https://linustechtips.com/topic/612997-annual-case-cleaning/#findComment-7922015
