D:/ Not Opening
Go to solution Solved by Spork829,
4 minutes ago, IPickle said:
Check disk management and see if the disk is recognised. If not, head onto the UEFI/BIOS and see if it is detected there.
You can open disk management by clicking: [Windows Key] + R and typing 'diskmgmt.msc'
Yep, and if it's not detected on either of those, it's either come physically unplugged or died.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/612759-d-not-opening/#findComment-7919501
42 minutes ago, GameMonsta said:
after getting into the bios which is a gigabyte motherboard btw, where should i look to find my drive?
I would look under boot devices or something like that.  Every BIOS is laid out a little differently and labels might be called different things.
https://linustechtips.com/topic/612759-d-not-opening/#findComment-7919810
