So to start of my specs:
Windows 10 64bit
I7 4770k no overclock
gtx 780 reference
8gb Ram
600 watt powersupply
asrock extreme3 motherboard
So my issue is a sort of odd one. I recently moved my computer into another room to play on my new htc vive and it worked great, the only thing was i had to switch audio sources from my previous one to the vive. Now I have moved my pc back to my main room and am having a weird problem I get weird 1 second stutters that freeze the audio and the screen or whatever I am doing at that time. At first I tried using my normal headphone jack on my pc and i got a weird buzzing when this stutter would occur. Reading up on forums I saw that there might have been a problem with realtek drivers so I reinstalled them same issue. After this I tried using my usb microphone which has a built in headphone jack (samson meteor mic) and deleted the realtek drivers completely but I still get the stutter and audio skip just without the buzzing, any help would be greatly appreciated.
https://linustechtips.com/topic/612669-possibly-audio-causing-stuttering/
Windows 10 64bit
gtx 780 reference
8gb Ram
switch audio source to your old one?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
