Hello
I was looking for a way to mount two Graphics Cards vertically behind each other. At first I thought about using 2 riser cables, but then I came across this:
AccessoriesB-2-Slot-PCI-Riser-Card-630.j
I cannot understand how something like this could work. Is it possible to use a similar product for PCI-e 16x and add two Graphics Cards on one slot? Doesn't this limit the amount of data which can be transferred simultaneously?
Thanks
https://linustechtips.com/topic/612546-riser-for-two-graphics-cards/
3 minutes ago, JMRC said:
Hello
Thanks
I'd think that each card would just end up running 8x.
4 minutes ago, JMRC said:
Hello
Thanks
This... seems to be an AGP splitterr, rather than PCIe.
It is possible to have a PCIE splitter, but that's not recommended.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
This makes me cringe, just looks like bottleneck heaven sorry.
let us all remember now and today, computers do not like abuse, they will fight back!
Old Skool KILLBOX. XEON E5640 4.0ghz / ASUS P6X58D-E ~ Noctua NH-L12 ~ eVGA GTX 670 SC 2GB 1312/7000 ~ 4TB 7200 RPM RAID0 ~ CoolerMaster Haf 922 ~ DELL P214H 23" 1080 IPS 2ms ~ HP w2007v 1680x1050. Now Playing: Splinter Cell OG XBOX / CSGO PC
Original XBOX - Xecuter 2 4981.67 Bios. Playstation 2 Slim SCPH-70002. Sega Dreamcast. N64
Hello
Thanks
That looks like PCI not PCI express...
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
12 minutes ago, JMRC said:
Hello
Thanks
How about this:
http://www.ebay.com/itm/Supermicro-RSC-R2UF-2E8GR-2U-RHS-PCI-Express-x16-PCI-Express-x8-Riser-Card-/331724041040?hash=item4d3c4b2b50:g:V8EAAOSw7FRWYKDQ
I'm not sure if this will be able to drive GPU's though, also the slots are too close together to fit 2 (dualslot) GPU's
Even if this would work your motherboard still needs to support SLI/Crossfire
6 minutes ago, JMRC said:
I know it isn't a PCI-e 16x, I said that in the question. But if something seems too good to be true ... it probably is. BTW you guys are really quick.
I would run two flexible pcie extensions like how the vertical gpus are mounted on the thermaltake p5.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
5 minutes ago, Jonathan Lemmens said:
16x being split to two 8x. I think that would hurt performance.
No it won't. This has been covered extensively by Linus and Luke. In many cases GPU's will be running in 8x anyway (or 16x/8x) in an SLI or Crossfire setup.
In, for example, a common Haswell/Skylake system there are only 16 PCIe lines coming directly from the CPU. On a motherboard with SLI capability, these same 16 lines would go to both x16 connectors, and the cards would each run x8. (Barring additional multiplexer chips.)
So, with this riser, you also have all 16 lines going to both sockets, and the cards would also run at x8.
That is to say, whether the slots are on the motherboard or on a riser card, they still only use the same 16 lines from the CPU.
About the only difference is the power delivery. This would work best if both graphics cards use external PCIe power connections rather than drawing power directly from the slot (although the power lines could be made heavier to allow for this).
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
