Hello,
I am currently looking to upgrade the Audio in my computer. I have never really looked into Audio that much before so this is kind of a new area for me.
Currently I am using the Corsair Vengeance 1500 USB headset which as treated me well the past few years but I keep switching them from my PS4 to PC and was looking for something to keep on my PC and use the 1500's just on the PS4.
I was thinking about getting a dedicated sound card and headset as I was told the quality would be better then using USB headsets. Is this information accurate?
Also my motherboard is a MSI Gaming Z97 (http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130770&_ga=1.180283172.1426973554.1466011553 ) which claims to have a good on board sound card. If I just buy a headset and use the onboard audio am I still going to get good audio quality?
Thanks
https://linustechtips.com/topic/612078-audio-upgrade/
We'll need a budget before we making any real suggestions, but as a start I would stick with your onboard audio for now and focus your budget toward your headphones/headset.
Main Rig:  CPU i5-4670k   MOBO Gigabyte Z97N-WIFI   GPU GTX 980ti    RAM 8GB  STORAGE 128GB ADATA(OS)/250GB Samsung 850 EVO(APPS)/3TB WD Red
AUDIO: AMP/DAC TEAC AI-301DA SPEAKERS: Cambridge Audio SX50 Phones: Philips Fidelio X1
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912203
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912211
Going by your points one by one:
- Don't get a sound card if you want more quality. You're much better off getting an external DAC/AMP combo. Just keep it external
- As for the headset, only a handful (Almost literally a handful) of headSETS are worth the money if you want quality sound (HyperX cloud 1/2 being one of them). In this scenario you would be better off getting a good pair of headPHONES (no mic) and buying a secondary mic to use. Either a clip-on $10 mic, a $50 modmic or something more expensive like a desktop mic (AT2020, Blue Yeti, etc.)
- Don't use headsets if you can avoid it unless you're going for something like the aforementioned HyperX cloud. Headsets are generally shit at proper audio. A dedicated sound card is generally better as long as it's a proper external DAC.
Remember to quote if you want us to see your answer ASAP!
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912224
my apologies, I would like to stay around $100.
3 minutes ago, 21rkosta said:
using those with the onboard would I receive better audio then the 1500's?
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912235
No worries, you've got a few options at that price point. The 518's that were previously suggested certainly would be a decent starting point. The 558's can also be had under $100. Either one will sound quite a bit better than your Corsair headset you have currently. Just add microphone. You won't need an AMP, I run my 558s off my iPhone no problem.
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912296
Just about every headphone (even $30 ones) are better than gaming headsets. There are only a handful of exceptions in gaming headsets that actually give good audio.
Do you want open-back or closed back by the way? Closed back provide (usually) better base response and makes noisy environments irrelevant. Open-backs however have much better soundstage (being able to tell where the sound is relative to you, extremely useful in games like CSGO)
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912314
perfect, Thank you for the quick reply. I will looking into the 518's and the 558's
They would mostly be used for gaming so I would probably say open-back. To be honest I didn't even know there was a difference.
https://linustechtips.com/topic/612078-audio-upgrade/#findComment-7912337
