Hi,
Lately I've being doing alot of encoding of media that only supports FAT32 file system which is annoying trying to keep the media under 4GB. Which I've achieved by using a video bitrate of 2500 and Mp3 Audio 320 (Yes, I don't use AAC due to horrible cracking/static but that's a whole different story) at full 1080p which I finally got a 3hour and 21minutes film at a file size of 3.96GB. But the downside to all of this are the "BLOCKS" or block artifacts due to the lower bitrate. (As seen in these screenshots)
Video bitrate: of 2500
Blu ray:
So is it worth even bothering with a FAT32 file system to watch your media on a non smart TV, because I understand that increasing the video bit rate will solve the block problem but will increase file size and get over 4GB file size.
(Another thing to note is I don't want my kids scratching my blu ray discs, so hooking up a blu ray player isn't my solution.)
Any other methods or settings for handbrake would be great.
Cheers.
https://linustechtips.com/topic/611936-encoding-for-fat32-file-system/
My TV has DLNA support, so I've been getting around this in the past by dropping the file on my mediaserver and streaming it. See if the TV supports other filesystems, if you haven't already.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
I was thinking about streaming as my next best option. But is there a affordable way to turn a non smart tv into one which I can acess my media library?
The Raspberry Pi is the easiest way to do it for a cost that won't break the bank, but unfortunately it doesn't support 4K and some people have been having problems with playing MKV files
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
