An EVGA G2 750 or 850 would be great.
750 if you won't OC much or have a tight budget (although you ARE getting dual 1080s :P )
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/611220-how-much-power-needed/#findComment-7903266
1 minute ago, Alexander1235 said:
I'm going to overclock the sh*t out of that system. 850w or 1000w?
850 W is plenty
https://linustechtips.com/topic/611220-how-much-power-needed/#findComment-7903274
10 minutes ago, Alexander1235 said:
Are you sure?
850W is plenty. The 1080 isn't power hungry. The 850W EVGA GS/G2 should work fine.
https://linustechtips.com/topic/611220-how-much-power-needed/#findComment-7903317
