So I turned on my PC but it turned to the install Windows screen cause I accidentally plugged a flash drive with a Windows 10 Iso on it. So I though whatever, not a problem, so I turned my PC off and unplugged the flash drive. Now it says no operating system found and to press control alt Delete to restart. Is there a difference between this and no boot drive found because I've gotten the no boot drive error before but never this.
Grump Bumb
https://linustechtips.com/topic/611138-no-operating-system-found/
Interesting. It could have corrupted your OS but it was just for a very short period of time.
I dont really know, never happened to me but 1st I would go into boot menu in BIOS and check what's going on in there and if it shows all my drives.
Then probably turned of my PC, unplugged all the drives but the one with OS and turn my PC back on to see if it helps. If so,then I would plug the drives back in as it was before :)
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
the installation most likely made changes to the bootloader, this can be solved by using the same usb drive and selecting repair instead of install
Me: Computer Engineer. Geek. Nerd.
[Educational] Computer Architecture: Computer Memory Hierarchy
[Educational] Computer Architecture:  What is SSE/AVX? (SIMD)
You should probably check in BIOS that your boot drive is the top of the boot priority list.
Other systems I've built:
I have a Samsung ssd but it says USB Samsung as the top boot priority but I don't have a usb Samsung flash drive, only the ssd
Grump Bumb
What are the other things in the boot priority list?
