K hey guyz greetings from India
I am building a new PC
Reason : sold my last one(the one in my description /  account)
PRIMARY USE : GAMING  1440p at 144hz
Secondary use :video editing 1080p
Also : writing blog (k i don't need a pc for that) and some college stuff
Budget  INR 150K(USD 2000or so)
Favorite color combo :black/red and white/red
Processor i7 6700k or I5 6500k (if the extra threads are not required)
Mobo
Asus maximus viii hero alpha (LEDs)
Gigabyte gaming z170x 7
If downsize is required
Asus z170 PRO GAMING
Gigabyte gaming z170x 5
Asrock extreme k6+
(ps don't likeMSI because there service sucks)
Gpu
Gtx 1080(if needed and available) or gtx 1070
Also looking for asus rog or gigabyte extreme gaming
Ram
Gskill ripjawsV (3200mhz) 2x 8 Gb
Storage
2tb WB Black /Seagate barracuda
256 gb Samsung evo 850 (Os drive)
Cooling
Deepcool gameraxx 240mm
Psu
Seasonic S12II 750W
Case (list is pretty long... So help me)
Brands
Circlect
Cooler Master
Corsair
Antec
Thermaltake
Nzxt
Requirements
240mm rad support
Atx support
Usb 3.0 support
Black /red color
Side window
Budget for case ₹10k ($150)
https://linustechtips.com/topic/611075-help-with-a-new-build/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($314.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($119.89 @ OutletPC)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($167.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2133 Memory  ($109.99 @ Newegg)
Storage: Samsung 850 Pro Series 512GB 2.5" Solid State Drive  ($214.99 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($53.00 @ Amazon)
Video Card: MSI GeForce GTX 1080 8GB Founders Edition Video Card  ($698.99 @ SuperBiiz)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($118.99 @ SuperBiiz)
Power Supply: SeaSonic 660W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($128.99 @ SuperBiiz)
Total: $1907.81
Generated by PCPartPicker 2016-06-14 08:48 EDT-0400
https://linustechtips.com/topic/611075-help-with-a-new-build/#findComment-7901495
I would save up on the RAM and motherboard, 2666-2400 is enough and most expensive boards aren't worth it. Also get a lower wattage power supply 750W is too much for one card 650-550 is more than enough.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/611075-help-with-a-new-build/#findComment-7901496
Total: $1907.81
32GB is too much for 1080p editing, stick with 16GB upgrade later if you need to.
https://linustechtips.com/topic/611075-help-with-a-new-build/#findComment-7901498
A few comments.
The MSI Z17OA Gaming M7 mother board is a pretty good alternative at a bit cheaper price. Its worth comparing to that Asus board.
1070 is adequate for playing 1440p. Not sure about at 144hz.
I've never used any of those cases, but I'm digging the fractal design layouts lately.
16gb DDR4 2400 ram is suitable for gaming
You have a pretty solid list. Good luck with it!
https://linustechtips.com/topic/611075-help-with-a-new-build/#findComment-7901502
2 hours ago, greaves1111 said:
A few comments.
Ps.... Msi service in India  sucks
A few comments.
And Asrock extreme 7+
Are in the same price  range
Also fractal design is not available in India
K... I am looking at 3200 mhz because the difference is rs 500($7)
https://linustechtips.com/topic/611075-help-with-a-new-build/#findComment-7902102
