CPU Issues
Solved by Nena Trinity,
8 minutes ago, Versydon said:I have had the CPU for about 2 weeks. And i have just discovered the issue today, but i have no temperature issues
That program is 100% unable to measure the temperature use AMD Overdrive, I personally suspect the motherboard is thermal throttling... ![]()
http://www.asrock.com/mb/AMD/960GM-VGS3 FX/
The board you got is clearly a motherboard made for 95w CPUs not 125w... ![]()
If I where you I would avoid OCing but you may be able to make it less unbearable like this... ![]()
