Hi i need a case like the corsair 600c where the windowed side panel is on the right side not on the traditional left side, i can only put my case to my left and i would like to show off my system or appreciate it when i look down.
dont know any other cases that are like the 600c
HEELP
CPU: Intel Core i3-3220 3.3GHz Mother Board: ASUS P8B75-M LE GPU: PowerColor Radeon HD 7770 GHz Edition RAM: Kingston 8GB (2 x 4GB) DDR3-1333 Case: Fractal Design Core 1000 Storage: Western Digital Caviar Blue 1TB PSU: Thermaltake LT-500NL2NL 500W
PERIPHERALS: Mouse: Logitech G502 Keyboard: Corsair K70 RGB Cherry MX Brown Monitor: Dell S2340L 60Hz 23.0" Speakers: Harman Kardon Soundsticks III Mouse Pad: Steelseries QCK Headphones: Superlux HD 668B
https://linustechtips.com/topic/610672-help-finding-a-case/
Why not just get the 600C?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/610672-help-finding-a-case/#findComment-7897324
first its expensive where i live and second i just wanted to know any other alternatives
https://linustechtips.com/topic/610672-help-finding-a-case/#findComment-7902259
5 minutes ago, bdub109 said:
I have the corsair air 240 and it can be rotated with window on top. The corsair logo in the front rotates to match. It's only micro atx or itx tho. Maybe the 540 atx version is the same way?
naah dont want it on the top, guess ill stick with the 600c thanks guys
https://linustechtips.com/topic/610672-help-finding-a-case/#findComment-7902362
