H110i - Older cooler, 2x 120mm fans.
H115i - Older cooler, 2x 140mm fans.
GTX and GT - Fancy reskin of the coolers with braided tubes and diffrent cpu block design.
There are a few degrees between them, but your best bet is probably buying the most recent one (GTX series). These also improve on reliability.
Edited by itsMilan
Autocorrect
May the force be with you - Yoda
6 minutes ago, Taylor Dettling said:
What are the differences between the Corsair h110i and the Corsair h115i? Also what about the GTX  and non-GTX versions of each?
Thanks,
Taylor
They are pretty much the same thing from what I can see.
With the biggest difference is where the hoses are sticking out from on the blocks. H115i comes out from the top of the block, where as the H110i GT comes out from the side of the block.
Both of them are using 2x 140mm fans. You're thinking of the H100.
Whoops, sorry.
Durped out. ?
