USB Unrecognized and Format BS
Go to solution Solved by Guest,
2 hours ago, paddy-stone said:
Which is why I posted the software for you to do it... I knew that there might be a problem. Mostly you get these sorts of problems when a USB disk has been used for a bootable drive. Follow the steps I said above and it'll be fine, takes about 10 seconds.
I got it, tried it out in OS X and did some research apparently it must be "master boot record" under the formatting label. It's strange that I couldn't have this done in Windows though to fix it. Anyway, thanks for the help.
I can't get my USB drives to be recognized for their actual size, they keep popping up as 200MB but their actual sizes are 4GB +. Anyone know how to solve this? I talked to Apple support about this and they didn't help at all. I talked to them because the drives were recently on OS X and I thought that was the issue.
This issue is happening with Windows.
https://linustechtips.com/topic/610324-usb-unrecognized-and-format-bs/
Check the USBs in Disk Management
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
1 minute ago, IAmLamp said:
ok then what
Does it show the expected size or the same reduced size?
2 minutes ago, IAmLamp said:
Thank you!!!!! Hey, yeah it shows 3.73 GB on the left, I don't know what the issue is though
Can you post a quick screenshot of it?
It's only seeing the first partition. Do you need anything off the drive?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
use this software  https://rufus.akeo.ie/
Untick the box that says "create a bootable disk" and format it. It will take off the other bootable partitions also and giev you the full capacity back.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
k what next?
You can format it with disk management to remove the extra partitions or use the software paddy-stone suggested.
1 hour ago, IAmLamp said:
It won't let me in disk management :\
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
